Vlad
Moderator
This is a great utility I thought I'd pass along, great for modern machines or those to like to beta test. Revo Uninstaller scans your HD and shows you a list of all the installed programs. What it does is first make a restore point in case you want the program back, then run the applications built in uninstaller and after that's done it scans for all traces left behind such as folders and Registry keys.
You'd be surprsed what gets left behind when you just use the built in uninstaller. All sorts of Registry keys and sometimes entire directory trees. Its a handy tool to keep around.
http://www.revouninstaller.com/
A portable version is available as well.
