Dwight Elvey
gslick
Look on page 1-2
Dwight
Look on page 1-2
Dwight
| VCF Latam | Apr 24 - 26, 2026, | Bahía Blanca, Argentina |
| VCF Pac. NW | May 02 - 03, 2026, | Tukwila, WA |
| VCF Southwest | May 29 - 31, 2026, | Westin Dallas Fort Worth Airport |
| VCF SoCal | See you in 2027, | Southern CA |
| VCF East | Apr TBD, 2027, | InfoAge, Wall, NJ |
Have a look at this manual here: http://vintagecomputer.ca/files/Roc...nput Output and Timer Module Users Manual.pdf
I am fairly certain this is the card but it's not in front of me. I already have pictures, I just haven't posted them yet. I may only have the 8K SRAM card as I have that manual and the 32K DRAM card manuals.
There is nothing about the RM 65 edge connector version boards that is STD Bus.
RM 65 Edge Connector version:
Width: 3.9 inch
Length: 6.5 inch
Edge Connector: 72-pin, 0.100 inch spacing
STD Bus:
Width: 4.5 inch
Length: 6.5 inch
Edge Connector: 56-pin, 0.125 inch spacing
gslick
Look on page 1-2
Dwight
Page 1-2 of what, this manual?
vintagecomputer.ca/files/Rockwell/AIM65/RM65%20General%20Purpose%20Input%20Output%20and%20Timer%20Module%20Users%20Manual.pdf
The Edge Connector Version of the RM 65 Bus cards are visually similar to STD Bus cards, but that's about it.
Might as well call Motorola EXORbus cards S-100 bus cards because they are visually similar at a gross level.
I know the RM 65 Bus cards were available in both 64-pin Eurocard versions, and 72-pin Edge Connector versions.
They weren't available in "STD Bus" versions, which has a specific meaning.
en.wikipedia.org/wiki/STD_Bus
If your usage of "STD" in this context just means an edge connector version, that is not entirely obvious, and somewhat confusing.
Have you powered up either of the AIM65s to see what they have in their ROMs. The basic AIM65 came with either BASIC or Forth but there were a lot of enhancement ROMs for them. There might be enough useful stuff on www.6502.org.
Looking at the floppy disk controller, it has a nice ROM with utilities like formatting to get a blank disk started.
Dwight
It is possible that this isn't as practical. I was looking at your Floppy controller board and the FDC manual. Your board has the AIM65 R324E ROM on it. That is the AIM65 DOS ROM. I'm not sure what my FDC card has but I suspect it is the R14C5 ROM. This is different and only has basic disk access code in it.Once you get the AIM working with the bus, you might want to look into the DOS work that Dallas Shell has done:
http://6502.org/users/dallas/SYM/SYMDOS2/symdos2.htm
I suspect it can be adapted to the RM65 floppy controller.
Dwight
