Here are some images for Sanyo.
http://oldcomputers-ddns.org/public/...nyo/index.html
mbc1200.td0 108,054 2014/3/24 [00:00:00] DSQD - SANYO MBC-1200 CP/M 2.2 SYSTEM DISK V1.5
mbc2000s.td0 151,386 2014/3/24 [00:00:00] SSQD - SANYO MBC-2000 CP/M 2.2 SYSTEM DISK
mbc2000u.td0 163,374 2014/3/24 [00:00:00] SSQD - SANYO MBC-2000 CP/M 2.2 UTILITIES DISK
mbc3000.td0 392,524 2014/3/24 [00:00:00] DSDD8 - SANYO MBC-3000 CP/M 2.2 SYSTEM DISK
mxo-sy21.zip 10,880 2014/3/24 [00:00:00]
san555.td0 208,126 2014/3/24 [00:00:00] DSDD - SANYO 555 MSDOS 2.11 SYSTEM DISK
sanyocom.zip 16,736 2014/3/24 [00:00:00]
smbc1000.td0 111,946 2014/3/24 [00:00:00] DSDD - SANYO MBC-1000 CP/M 2.2 SYSTEM DISK
smbc1100.td0 101,060 2014/3/24 [00:00:00] DSDD - SANYO MBC-1100 CP/M 2.2 SYSTEM DISK
smbc1200.td0 114,222 2014/3/24 [00:00:00] DSQD - SANYO MBC-1200 CP/M 2.2 SYSTEM DISK V1.3
Download the .td0 files you want, then download the Imagedisk Ver1.18 from Dave Dunfield's website.
It includes utilities like TD02IMD, IMDA, IMDU, IMDV, BIN2IMD, ANY2IMD, DMK2IMD, and TESTFDC.
Create a batch file named A.BAT that contains:
TD02IMD smbc1100.td0 > SMBC1100.TXT
IMDA SMBC1100.IMD >> SMBC1100.TXT
IMDU SMBC1100IMD SMBC1100.RAW /B /E /D >> SMBC1100.TXT
Then run the A.BAT file on the DOS Computer that has the correct Floppy Attached. Note that
TELEDISK and IMAGEDISK (IMD) are DOS programs that run on an older DOS Computer.
Read through the SMBC1100.TXT file as it will give you lots of information on the image.
TD 1.4 5.25 LD MFM S-step, 2 sides ADV
80 tracks, 1280 sectors converted.
IMageDisk Analyzer 1.18 / Mar 12 2012
IMD TD 1.4 5.25 LD MFM S-step, 2 sides ADV
Required cylinders: 40
Required heads : 2
Data rate : 250kbps
Est. maximum track: 5541 bytes
Possible drives/options to write SMBC1100.IMD :
5.25" DD 40-track
Double-step: OFF
5.25" QD 80-track
Double-step: ON
5.25" HD 80-track
Double-step: ON
250 kbps -> 300 kbps
3.5" DD 80-track NOTE: *1
Double-step: OFF
3.5" HD 80-track NOTE: *1
Double-step: OFF
*1 40 track image will use only first 1/2 of 80-track drive.
IMageDisk Utility 1.18 / Mar 07 2012
Assuming 1:1 for Binary output
0/0 250 kbps DD 16x256
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
D D D D D D D D D D D D D D D D
0/1 D D D D D D D D D D D00 D00 D00 D00 D00 D00
1/0 D D00 DE5 D D00 DE5 D D00 D D D00 D DE5 D D DE5
1/1 D D D D D D D D D D D D D D D D
2/0 D D D D D D D D D D DE5 D D DE5 D D
2/1 D DE5 D D DE5 D D DE5 D D DE5 D D DE5 D D
3/0 D D D00 D D D00 D00 D D00 D00 D D00 D00 D D00 D00
3/1 D D D D D D D D D D D D D D D D
4/0 D D D D D D D D D D D D D D D D
4/1 D DE5 DE5 D DE5 DE5 D DE5 D DE5 DE5 D DE5 DE5 DE5 DE5
5/0 D D D D D D D D D D D D D D D D
5/1 D DE5 D D DE5 D D DE5 D D DE5 D D DE5 DE5 D
6/0 D D D D D DE5 D D D D D D D D D D
6/1 D D D D D D D D D D D D D D D D
7/0 D D DE5 D D DE5 D D D D D D D D D DE5
7/1 D D D D D D D DE5 D D DE5 D D DE5 D D
8/0 D DE5 DE5 D DE5 DE5 D DE5 D D DE5 D D DE5 D DE5
8/1 D D DE5 D DE5 DE5 D DE5 D DE5 DE5 D DE5 DE5 D DE5
9/0 D D D D D D D D D D D D D D D D
9/1 D D D D D D D D D D D D D D D D
10/0 D D D D D D D D D D D D D D D D
10/1 D D D D D D D D D D D D D D D D
11/0 D D D D D D D D D D D D D D D D
11/1 D D D D D D D D D D D D D D D D
12/0 D D D D D D D D D D D D D D D D
12/1 D D DE5 D00 D DE5 D00 D D D00 D D D00 D D DE5
13/0 D D D D D D D D D D D D D D D D
13/1 D D D D D D D D D D D D D D D D
14/0 D D D D D D D D D D D D D D D D
14/1 D D D D D D D D D D D D D D D D
15/0 D DE5 D D DE5 D D DE5 D D DE5 DE5 D DE5 DE5 D
15/1 D D D D D D D D D D D D D D D D
16/0 D D D D D D D D D D D D D D D D
16/1 D D D D D D D D D D D D D D D D
17/0 D D D D D DE5 D D D D D D D D D D
17/1 D D DE5 D D DE5 D D D D D D DE5 D D DE5
18/0 D D D D D D D D D D D D D D D D
18/1 D D D D D D D D D D D D D DE5 D D
19/0 D D D D D D D D D D D D D D D D
19/1 D D D D D D D DE5 D D DE5 D D DE5 D D
20/0 D DE5 D D DE5 D D DE5 D D DE5 D D DE5 DE5 D
20/1 D DE5 D D DE5 D D DE5 D D DE5 DE5 D DE5 DE5 D
21/0 D D DE5 D DE5 DE5 D DE5 D D DE5 D DE5 DE5 D DE5
21/1 D D DE5 D D DE5 D D D D DE5 D DE5 DE5 D DE5
22/0 D DE5 DE5 D DE5 DE5 D DE5 D D DE5 DE5 D DE5 DE5 D
22/1 D DE5 DE5 D DE5 DE5 D DE5 DE5 D DE5 DE5 DE5 DE5 DE5 DE5
23/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
23/1 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
24/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
24/1 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
25/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
25/1 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
26/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
26/1 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
27/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
27/1 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
28/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
28/1 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
29/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
29/1 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
30/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
30/1 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
31/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
31/1 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
32/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
32/1 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
33/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
33/1 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
34/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
34/1 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
35/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
35/1 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
36/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
36/1 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
37/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
37/1 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
38/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
38/1 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
39/0 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
39/1 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5 DE5
80 tracks(40/40), 1280 sectors (686 Compressed)
#22DISK
BEGIN SAN1 Sanyo MBC-1000, MBC-1150 - DSDD 48 tpi 5.25" - 256 x 16
INSERT 22DISK DEFINITION HERE
END
#cpmtools
# SAN1 Sanyo MBC-1000, MBC-1150 - DSDD 48 tpi 5.25" - 256 x 16
diskdef san1
seclen 256
tracks 80
sectrk 16
blocksize 2048
maxdir 64
skew 3
boottrk 2
os 2.2
end
# libdsk data below
[san1]
description = SAN1 Sanyo MBC-1000, MBC-1150 - DSDD 48 tpi 5.25" - 256 x 16
sides = alt
cylinders = 80
heads = 2
secsize = 256
sectors = 16
secbase = 1
datarate = DD
#GOTEK/Flashfloppy
[san1]
cyls = 80
heads = 2
secs = 16
interleave = 3
bps = 256
id = 1
#rpm = 360
rpm = 300
rate = 250
mode = mfm
iam = no
$ cpmls -f san1 -D SMBC1100.RAW
Name Bytes Recs Attr update create
ASM .COM 8K 64 R
BAR .BAS 2K 11 R
BASIC .COM 30K 234 R
CHR$ .BAS 2K 2 R
CPM .SYS 4K 22 R
DCOP .COM 4K 19 R
DDT .COM 6K 38 R
DDUMP .COM 4K 17 R
DUMP .COM 2K 4 R
ED .COM 8K 52 R
FDUMP .COM 4K 24 R
FILECOPY.COM 2K 11 R
FORMAT .COM 2K 8 R
FRCV .COM 2K 8 R
FTRN .COM 2K 8 R
LINE .COM 2K 8 R
LOAD .COM 2K 14 R
MERGE .COM 14K 110 R
MOVCPM .COM 10K 76 R
PIP .COM 8K 58 R
SORT .COM 22K 162 R
STAT .COM 6K 42 R
SUBMIT .COM 2K 10 R
SYSGEN .COM 2K 6 R
VERIFY .COM 2K 8 R
XCHG .COM 8K 58 R
XREF .COM 10K 78 R
XSUB .COM 2K 6 R
28 Files occupying 172K, 138K Free.
#cpmcp -f san1 SMBC1100.RAW 0:*.* /home/larry/IMDs/Sanyo-MBC-1000/SMBC-1100
Required heads : 2
Data rate : 250kbps
Double Density 16 Sectors x 256 bytes per sector
Write the Image to a 5.25" DS/DD Floppy with IMD using 40 Tracks Single Step for a 360K Drive.
Boot on the SBC.
Larry
