The photo of the label on the back and the description for this item listing both say DV-31ATB-A, which as far as I can tell would be a KA41-A M10 CPU (90ns), not a KA41-D M10e CPU (60ns). I couldn't be sure myself which one it is without opening the system to take a look at the part number on the motherboard, or powering up the system to see if the firmware reports a KA41-A or a KA41-D CPU.
I have a couple of the 3100 M20 version, which is the same as the M10 version except in the slightly larger case. They are fairly slow compared to any other VAX systems you might find except the MicroVAX / VAXstation II and 2000. If you don't have any VAX systems and you want to try one out they are aren't that bad of a start if the price is right and they come with the max 32MB of RAM. If you got one with just the base RAM on the motherboard you could easily spend almost as much for the somewhat rare memory expansion boards as you did for the whole CPU to max out the RAM.
The maximum supported SCSI hard drive capacity is 1GB (1,073,741,824 bytes) due to the firmware 21-bit LBA limit. You can however use larger SCSI hard drives if you soft resize the capacity down to the 1GB limit. I have done that and it works fine the the pile of 9GB drives I have.
One interesting thing that can be done with a MicroVAX 3100 M10/M10e/M20/M20e is turn it into an InfoServer 100/150 by replacing the firmware EPROMs. That is really only useful if you have other VAX systems that don't have a local CD-ROM drive which you want to boot and do a software install on over the network, or you have a VXT terminal you want to boot from an InfoServer.
If you don't already have any MMJ adapters to connect to standard DB25 ports on a terminal or PC you could pick up some of these H8571-A for $5 including shipping. That's about as cheap as I ever see those on eBay.
http://www.ebay.com/itm/131921579216
For reference:
MicroVAX 3100 / VAXserver 3100 / InfoServer 100 SYSTEMS
Illustrated Parts Breakdown
EK-A0372-IP-003
A0372IP3.PDF (
http://decdoc.itsx.net/dec94mds/a0372ip3.pdf)
CPU Boards:
54-18856-01 MicroVAX 3100 Model 10 / Model 20 KA41-AA (90ns)
54-18856-02 VAXserver 3100 Model 10 / Model 20 KA41-BA (90ns)
54-18856-04 MicroVAX 3100 Model 10e / Model 20e KA41-DA (60ns)
54-18856-05 VAXserver 3100 Model 10e / Model 20e KA41-EA (60ns)
70-28103-01 InfoServer 100 KA41-CA
54-18856-06 InfoServer 150
