Tr3vor
I got a pentium 75mhz machine from a thrift store two days ago. It had Windows 98 Plus on it. That was far too slow so I installed DOS 6.22.
So the problem here seems to be that the PnP bios is choosing parameters for the SB16 Vibra card I have that conflicts with other stuff. Every time I take the card out or put it in the bios tells me that its Updating the ESCD. Every time it says that, the computer will boot. So, when I leave the card in there and just turn it on later, it won't say "Updating ESCD" and it will just freeze before it loads anything from the HDD or FDD.
So from what I know is that ESCD is something that saves PnP ISA card configurations. So I'm guessing the computer saves the configuration for the SB16 and then a reset after that, wants to set a system device to the same parameters and it fails to boot. I can change the DMA channel for the parralell port in the bios to get it to update the ESCD and boot again, but that just lasts for that one boot. If I restart again, it freezes.
BTW, the bios is "Award Modular BIOS 4.50pg" I'm wondering if its the BIOS's fault and if I need to update that.
So I'm not sure if I explained this adequately, its kinda hard to put into words, but If I need to I'll make a video showing its behavior. Thanks in advance for any advice.
I also bought an AWE64 for this computer the other day, hopefully that works better than this sb16 vibra...
