fatwizard
I acquired an AT tower case a while back, and I just got around to cleaning it up and building a system with it. I had a socket 5 motherboard with a Pentium 90 already setup for this project. As I am installing Windows 95 I notice there is no mouse pointer. I was using the onboard serial ports, so I check the ribbon cable and header. I verify that the ribbon cable is plugged into the header on the motherboard the correct way. I checked CMOS that the serial ports are enabled. I toggled them in CMOS, off then back on. No soap. I have several serial mice which work fine, but none are detected with this setup. I finally pulled the motherboard and substituted another very similar motherboard. Same result with a different motherboard.
This time I tested the built in serial ports with Checkit and a loopback connector. COM1 and COM2 pass with flying colors. I tried a serial expansion card, and the mouse is detected properly using that. I put a socket 7 board on the bench and found it would not detect a serial mouse on the onboard ports either. I have done this sort of thing in the past more times than I can count, and I am flummoxed that it now doesn't work.
I have a feeling I am having a senior moment with this, like I am forgetting some step that I used to remember without trying.
Maybe someone can jog an old man's memory.
