Hugo Holden
Eudi said:
For instance, the 40 column PET (the ones with "hardwired" video pre-dating the CRTC-equipped ones) demonstrates a way to do it. TL;DR, it essentially breaks display memory into 8 byte pages that are incremented directly and "recirculates" the higher address bits through a latch that preloads the counters at the start of the active area of each line. For an 80 column screen you could duplicate this *almost* exactly; just move the addressing over 1 bit to use 16 byte pages.
It is an interesting recirculating circuit, even impressive drawn on paper because it is a loop. In these cases it is a good thing that gates, flip flops etc have a data transmission delay, so the input data stays stable enough to be used, before it changes to a new value later after a change in state.
Though data latches help, and if a two phase clock is used, breaks up what amounts to read and write states into separate temporal events.
One of the more simple examples of a logic loop like this, is the D type flip flop, to get it to toggle you can connect its /Q output into its D input and usually, the data at the D input stays stable long enough for it to toggle reliably on each clock pulse. One way you can make it ignore multiple transitions on a clock signal (say from a poorly de-bounced switch) is to put an RC delay (or a logic gate delay) in the /Q to D link. Still, making a toggling flip flop this way is not nearly as reliable as using a JK flip flop with both J&K held high. The D flip flop wired to toggle with this short loop can sometimes give trouble near the high frequency end of the logic family's operating range.
