smeezekitty
I just received my S3 Virge video card.
The graphical BIOS with mouse support is so cool. Long before UEFI
Thanks!Those cards are pretty much supported by any OS you want to throw at it. Have fun.
I would like to suggest something about the RAMs.
128RAM can have better than double of the 64ram on overall performance.
This means that 128RAM has siginificant performance improvement than 64MB not just 64MB more and worth to invest on 128mb RAM.
I would suggest we use as few pieces of RAM as we can to get the very slightly better performance.
eg, 64x2 is better than 16x8.
Hope this helps.
Bill
Tech Manager, WPTinc.
Navr*til Software System Information
Version 0.60.45
Report File
Tuesday, 2014-04-22 19:46
Switches: /AR
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛGeneral InformationÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
º Computer PC-AT or compatible, ISA + PCI º
º Processor Intel i486DX or i487SX, 120 MHz, V86 mode, 2/4/19/15 º
º Co-Processor Internal, 120 MHz, 3/3/100/22 º
º BIOS AMI WinBIOS, American Megatrends, Inc., PnP, 10/10/94 º
º Video Diamond SVGA 4 MB, VESA VBE 1.2, Secondary: None º
º Memory 16 MB, 640 KB, 15360 KB, XMS(3.0,15296 KB), EMS(4.0,15 º
º Drives HDD1: 488 MB º
º Oper. System MS-DOS version 6.0 º
º Mouse Not Detected º
º Input Devices AT Enhanced Keyboard (101 key), Ncsi, No Joystick(s) º
º Ports 2 Serial, 1 Parallel, 0 Game º
º CMOS FDD1: 1.44 MB 3«", FDD2: None º
º Network Not Detected º
º Multimedia Not Detected º
º Software Not Detected º
º Other Not Detected º
ÈÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍͼ
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛComputer DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
ºÄ General ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Computer Type PC-AT or compatible º
º Computer Name Unknown or Noname º
º Model FCh º
º Submodel 01h º
º Revision 00h º
ºÄ Mainboard ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Bus(es) ISA + PCI (2 devices) º
º Chipset SiS 496/497 (Method 1) º
º Manufacturer AOpen (Acer Inc.) (Method 2) º
º Type AOpen AP41/AP43 º
º System Bus Speed 120 MHz (multiplier 1.0x) (Method 1) º
ºÄ ISA Devices ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º No Devices/Cards Found º
ºÄ EISA Devices ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º EISA Bus Not Present º
ºÄ PCI Bus Features ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º PCI/AGP Bus Version 2.10/n/a º
º Number of Last PCI Bus in System 0 º
º Configuration Space Access Mechanism 1 Supported º
º Configuration Space Access Mechanism 2 Not Supported º
º Special Cycle Generation Mechanism 1 Not Supported º
º Special Cycle Generation Mechanism 2 Not Supported º
ºÄ PCI Bus Devices ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Vendor ID 1039h, Device ID 0496h, Bus 0 - PCI, Device 5, Function 0 º
º Vendor Silicon Integrated Systems º
º Device SiS 85C496/497 486 Chipset (CPU/PCI & PCI/ISA Bridge) º
ºÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Vendor ID 5333h, Device ID 5631h, Bus 0 - PCI, Device 11, Function 0 º
º Vendor S3 Incorporated º
º Device S3 ViRGE (86C325) Video Adapter º
ºÄ PCI Bus Device Characteristics ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Device Class PCI/Host Bridge º
º Device Revision 31h º
º Interrupt Line None º
º Interrupt Pin None º
º ROM Base Address n/a º
ºÄ PCI Bus Device Features ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º I/O Space Access Enabled º
º Memory Space Access Enabled º
º Bus-Mastering Enabled º
º Wait Cycles Disabled º
º Fast Back-to-Back Disabled º
ºÄ PCI Bus Device Capabilities ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Running at 66 MHz Not Capable º
º Fast Back-to-Back Capable º
º Device Timing Medium º
º Device Class VGA Compatible Adapter º
º Device Revision 06h º
º Interrupt Line IRQ9 º
º Interrupt Pin INTA# º
º ROM Base Address 80000000h º
º Fast Back-to-Back Not Capable º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛProcessor DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
º Main Processor Intel i486DX or i487SX, 120 MHz º
º CPU ID n/a º
º Stepping n/a º
º CPU Vendor n/a º
º CPU Name n/a º
º CPU Serial Number n/a º
º Run Mode Virtual 8086 º
º CPU Type Original OEM Processor º
º 1st Level Cache 8 KB (Method 1) º
º 2nd Level Cache n/a º
º 3rd Level Cache n/a º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛCo-Processor DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
º Co-Processor Type Internal, 120 MHz º
º Communication Protocol 32-bit º
º Co-Processor Emulated No º
º Emulation Software n/a º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛBIOS DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
º BIOS Type AMI WinBIOS º
º BIOS Manufacturer American Megatrends, Inc. º
º BIOS Date 10/10/94 º
º BIOS Version n/a º
ºÄ BIOS Features ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Flash BIOS Present (AMI, version 2.00) º
º Green PC/Energy Star Present º
º BIOS32 Services Present º
º Plug and Play Support Present (version 1.0, 0 devices) º
º DMI Support Not Present º
º SMBIOS Support Not Present º
º APM Support Not Present º
º ACPI Support Not Present º
º ACFG Support Not Present º
º PCI IRQ Routing Table Not Present º
ºÄ ROM Modules ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Address Range Size Type PnP º
º C000h - C7FFh 32 KB SVGA BIOS º
º E000h - E0FFh 4 KB System ROM º
ºÄ Plug and Play Devices ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º No Plug and Play Devices Present º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛVideo DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
º Video Adapter SVGA º
º Monitor Type SVGA Digital Color º
º Secondary Video Adapter None º
º Secondary Monitor Type None º
º Video Chipset S3 ViRGE (86C325) (Method 4) º
º Video Card Diamond Stealth 3D 2000 º
º Video Memory Size 4 MB º
º Video Card Bus PCI º
º Video RAMDAC Type S3 ViRGE Internal SDAC TrueColor, 135 MHz º
º Video BIOS Manufacturer S3 Inc., Diamond º
º Video BIOS Model Stealth º
º Video BIOS Version 1.04 º
º Video BIOS Date 01/23/97 º
ºÄ VESA Information ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º VESA Support Present (VESA Memory Size 4 MB) º
º VESA VBE Version 1.2 º
º VESA Manufacturer S3 Incorporated. 86C325 º
º VESA Power Management Present, VBE/PM version 1.0 º
º Display Data Channel Present º
º Accelerator Functions Not Present º
º Audio Interface Not Present º
º Flat Panel Interface Not Present º
º Cursor Interface Not Present º
º Graphics System Conf. Not Present º
ºÄ VESA VBE 2.0 Information ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º OEM Software Version n/a º
º Vendor Name n/a º
º Product Name n/a º
º Product Revision n/a º
ºÄ 3D Graphics Acceleration ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Internal 3D Accelerator S3 ViRGE º
º External 3D Accelerator No Known Found º
ºÄ Monitor Information ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Monitor Name DELL 1901FP º
º Monitor Type 21" º
º Viewable Image 19.3"/49 cm º
º Serial Number 1094988621 º
º Date of Manufacture 29. week of year 2004 º
º Max. Horizontal Size 38 cm º
º Max. Vertical Size 31 cm º
º Display Type RGB Color º
º Voltage Level 0.700V/0.300V (1.000V p-p) º
º Input Signal Type Analog, Composite Sync, Sync on Green º
º Gamma Factor 2.20 º
º DPMS Support Standby, Suspend, Active OFF º
ºÄ Additional Video Information ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Video BIOS Segment C000h º
º Video BIOS Size 32 KB º
º Scan Lines 400 º
º Character Size 9 x 16 º
º EGA Switches 0110 º
º CGA Cursor Emulation Disabled º
º Current Video Mode 3 º
º Video Segment Address B800h º
º Video Page Size 4 KB º
º CRTC Port 3D4h º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛMemory DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
º Total Memory 16 MB, Memory over 1 MB 15360 KB º
º HMA Exists Yes º
ºÄ Conventional ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Total 640 KB, Used 249 KB (39%), Free 391 KB (61%) º
º Used by DOS 22 KB (3%) º
ºÄ XMS ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Present Yes, Version 3.0 º
º Manager HIMEM, Revision 3.09 º
º Total 15296 KB, Used 1273 KB (8%), Free 14023 KB (92%) º
ºÄ EMS ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Present Yes, Version 4.0 º
º Manager EMM386, Revision 3.09 º
º Total 15680 KB, Used 1424 KB (9%), Free 14256 KB (91%) º
º Page Frame D000h º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛDrives DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
ºÄ IDE Drives ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Primary Master IDE Drive º
º Primary Slave None º
º Secondary Master ATAPI Drive º
º Secondary Slave ATAPI Drive º
º Tertiary Master None º
º Tertiary Slave None º
º Quaternary Master None º
º Quaternary Slave None º
ºÄ Non-IDE Drives ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º None Found º
ºÄ ATAPI Drive Physical Information ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Drive Model pppppppppppppppppppp º
º Firmware Revision pppp º
º Serial Number pppppppppp º
º Device Type Unknown º
º Drive Features DMA º
º Drive Manufacturer Unknown º
º Estim. Drive Speed n/a º
º Removable Device Yes º
º Transfer Modes PIO 8, SW DMA 3/6, MW DMA 0/6, Ultra DMA 0/6 º
º Drive Features DMA, IORDY º
º Transfer Modes PIO 8, SW DMA 3/6, MW DMA 3/6, Ultra DMA 3/6 º
º L Drive Type Label Total Free Used º
º A: Floppy Drive 1.44 MB 3«" n/a n/a n/a n/a º
º C: Local Hard Disk n/a 486 MB 480 MB 6 MB º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛOperating System DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
º Operating System MS-DOS º
º DOS Version 6.0 º
º True DOS Version 6.0 º
º DOS Revision 0 º
º User Serial Number 000000h º
º DOS OEM Microsoft or Phoenix º
º DOS is in HMA º
º Boot Drive A: º
º Last Drive Z: º
º BREAK Off º
º VERIFY Off º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛPorts DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
ºÄ Serial ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º COM Port UART TimeOut Rate Data Stop Parity CD RI DSR CTS º
º 1 03F8h 16550A 1 s 1200 bps 8 b 1 b None No No No No º
º 2 02F8h 16550A 1 s 1200 bps 8 b 1 b None No No No No º
ºÄ Parallel ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º LPT Port EPP TimeOut TIM IOE SEL OOP ACK NBZ º
º 1 0378h n/a 20 s No No Yes Yes No No º
ºÄ Game ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º JOY Position X Position Y Button 1 Button 2 º
º 1 0 0 Released Released º
º 2 0 0 Released Released º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛNetwork DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
ºÄ Detected Network(s) ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º No Networks Detected º
ºÄ Network Services/Protocols ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Not Detected º
ºÄ Network Card(s) ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º No Network Cards Detected º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛMultimedia DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
ºÄ Sound Card ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º BLASTER Type Non-Creative Labs card compatible with SB 2.0 Bits n/a º
º Specific Type same as above Bits n/a º
º Settings Port n/a, IRQ n/a, DMA n/a, High DMA n/a, MIDI Port n/a º
º DSP Version n/a T 1 º
º AWE Features n/a º
º Compatibility n/a º
º Features n/a º
º Manufacturer n/a º
º DSP Copyright n/a º
º Accelerator No Known Found º
ºÄ CD-ROM ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º MSCDEX Status Not Installed, Version n/a º
º CD-ROMs 0, Letter(s) n/a º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛSoftware DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
ºÄ Detected Software ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Microsoft EMM386 or compatible, Mode ON º
º Virtual Control Program Interface version 1.00 º
º XMS Memory Manager º
ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛOther DetailsÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ
ºÄ Miscellaneous ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º Modem Status Not Found º
º Modem Type n/a º
º Scanner Not Found º
ºÄ PCMCIA Information ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º PCMCIA Not Present º
Good. You'll propably find there's a lot of script errors as well. Try and get hold of Opera 10ish if you are using IE.
Congrats! Is that with Opera 8 on Win 95?
Thanks!
Yes it was Opera 8.5 on Windows 95. Now using Opera 9.6 on Windows 98
Not as horrible as I expected it would be.
The CF card slot in the back makes it easy to switch OSes in less than two minutes.
---edit---
Where is the hoss file on 9x? Its been a long time
OK, so I thought I would try Opera 8.5. I uninstalled Opera 6 which worked fine, and installed Opera 8.5 It can't connect or find any server. (this is an ethernet connection to the router) IE 5 connects just fine. OE email connects fine. I reran Internet wizard from cp, and still no connection on Opera. I rebooted several times. I uninstalled, rebooted and reinstalled. nothing. Then I tried Opera 8.54. Same thing. Opera just won't connect from my Windows 95 Gateway. Only IE 5.5 works (even the old Opera worked.) Am I overlooking something? I really like the look of Opera 8.5 too.
