Thanks stone... I followed your link and already found several items I like. However, like I've said many times before... I really do know absolutely nothing about these boards, or really anything until I began actually troubleshooting, and then I've never had to piece together a setup like this. I'm including links to each of the items I intend to purchase, so hopefully you'll all be able to tell if I'm getting the right things. As with all things, it's good to learn. And I'm actually learning something.
Yes, this is really already turning into a fun build. By looking at the items I chose to link to below, I think you should be able to see what I'm doing.
Parallel Port on bracket
http://www.ebay.com/itm/Parallel-LP...674?pt=LH_DefaultDomain_0&hash=item337df6d9aa
Dual Serial Port on bracket
http://www.ebay.com/itm/2-in-1-2-po...rial_PS_2_Cables_Adapters&hash=item484ede95e3
USB PS2 on bracket
http://www.ebay.com/itm/Dual-USB-2-..._USB_Cables_Hubs_Adapters&hash=item43b4138cd6
However, I think I already have a 4 port USB bracket with the mobo connectors. Still, I think this will be a simple way for adding USB, AND dual PS2 ports for the keyboard and mouse.
Lastly: If the mobo accepts 3 floppy drives, or possibly an internal USB connection, I would also like to get a 3.5" multi-card reader to occupy the 2nd 3.5" expansion bay.
OK, there you have it; my shopping list. Did I miss anything?
