Hi, I'm putting together a "twinner" box based on DFI i810 chipset mobo (only one I have that supports 2 floppy drives). Idea is to have all 3 common floppy formats in one convenient box, 360Kb 5.25", 1.2Mb 5.25" and 1.44Mb 3.5".
The problem of having all 3 solved by buying a LS120 drive on ebay, actually it's a scsi drive but the adapter board it's easily removable so what I'm actually using is a plain vanilla IDE LS-120 that also doubles as a third floppy ( windows 98 recognized it no problem and assigned letter d.
So far so good I thought, brought my pile of 5.25" drives from the basement and started picking the best looking ones to test. Didn't have any problems picking up a good working 1.2Mb drive, but to my surprise I only found only one 360Kb drive in the pile . .
Needless to say the drive doesn't work properly, the spindle spins but the heads don't move at all ! , it doesn't matter what position I've set the manually before the power up. I've tried all the jumper combinations and they seem to work right ( they do what they're supposed to do according to the manual).
Tried it as a DS 1 in both positions on the cable, works fine as far as spindle concerned but the head doesn't move at all, power seems to be OK, capacitors check out good also, I've checked all 3 sensors they're OK too.
And that's the moment that I'd like some help guys.
While finding a user manual wasn't hard ( bitsavers has it), a service manual would help here immensely,
either a full service manual or even a schematic only. I know some of you specialize in that kind of stuff, pretty sure someone must have it, after all it's, sorry was a quite popular drive and Tandon's service manuals are out there, just couldn't find one for this particular unit.
Here's a couple of pictures of the culprit:
