I think this is what you are looking for already on archive.org:Looking for someone who could provide me with the Digi-Mouse driver (MOUSE.SYS) for the Tandy 2000 on a 5 1/4 inch diskette that my 2000 can load. I will pay for the diskette and shipping.
Thanks
This diskette for sale on eBay is for the Tandy 1000, but I think it should work on the Tandy 2000 Digi-Mouse/Clock board as well.I have no means to put that file on my T2K's boot disk. I have the other files for the clock and they work fine. The one for the mouse seems to be corrupt. I also have Windows 1.01 and the mouse works perfectly, so it isn't the hardware.
I hope it works for you as well!I just bought it. Let' hope it will work. I'll let you know as soon as I receive it. Thank you.
I doubt he can. He already said that he has "no means to put that file on my T2K's boot disk", so unlikely he can do the other way. Sounds like he has nothing else with a 5.25" disk drive to do any transfers.If so, please upload a copy.
The serial ports in the 2000 are NOTHING like the serial ports in a regular PC. Just because it uses the same connector doesn't equate to the same protocols, ports or addresses.
It isn't, otherwise it would not be RS232.but how are the RS232 ports different from any others?
Not sure what he was refering to... Maybe the Tandy 2000 has different kind of serial ports?
I went off the rails in mentioning the serial ports.The Tandy 2000’s built in serial port is very implemented very differently from a standard PC port (uses an Intel 8251 UART instead of a NatSemi 8250, the addressing and interrupt setup is nothing like a standard PC, etc) so any software that accesses the serial hardware directly instead of through the BIOS would need to be patched…
But this thread is about the Digi-Mouse, which isn’t a serial mouse, so how did this come up?
The 2000 is almost completly different than any PC compatible. Look for drivers made specifially for the 2000.
Serial ports do not apply here.
The Digi-Mouse is basically a Bus Mouse with a DB9 connector. In theory it should operate the same on the Tandy 1000 or Tandy 2000 with a Digi-Mouse./Clock board.
