Trixter
(Having hosted the Tandy 1000 FAQ for many years, and able to use search engines, you'd think I'd be able to find the answer to this... but after 30 minutes of searching, I figured I'd just ask people who have been through this already
I have a functional Tandy TL/2 with a semi-functional WD-93044-X. It works, but it takes several minutes of warming up and operation to allow reading without errors. Since it's an 8-bit IDE interface, can I assume that replacing it with a CF card+adapter should work ok, or does the built-in controller only recognize certain models?
If the latter, should I resign myself to adding an XT-IDE once the original drive fails? With DOS in ROM (which I don't ever want to disable), is there room for the XT-IDE's XUB anyway?
