mnbvcxz
I cannot give you any advice on troubleshooting, hopefully someone more knowledgeable will help you.
Thank you, I'd bet money on the power supply smoking. Would it be cheaper to replace a cap or just replace the whole thing? I heard you could replace it with a normal power supply out of a modern desktop machine.
FOUND IT! It was this paper looking square thing, looks as if it was a capacitor. Photos
Just to give you a bit of a heads up, thats not a Model 4 Astec 65W power supply, thats a Model III Astec 35W power supply (as fitted to most Model IIIs and cassette based M4s). The power connections are different. M3 supply has 3 connectors with 4 prongs each, whereas the M4 supply has one long connector with 12 prongs and one missing.
On the plus side the M3 Astec 35W supplies are nearly indistructable so just replace the 3 Rifa caps with modern MKT caps and they power supply with filter like it was supposed to.
I'm betting your computer started life out as a cassette based M4, and its cat. no. is 26-1067. To put a M4 Astec 65W supply into your system will require a wiring loom from said disk based M4 computer.
Hope this helps,
Ian.
