IMSAI-Micha
- Joined
- Oct 13, 2024
- Messages
- 20
Hello, my name is Mikel, I'm also new in this forum
. I'm in my mid-50s.
I just like old technology and especially terminals with baud rates of 300 to 19200 baud.
I recently bought a used TeleVideo PT100 Personal Terminal.
Unfortunately, it doesn't work properly anymore.
The keyboard itself works wonderfully. I also connected a WiFi modem for testing and data reception at 2400 baud also worked.
But every time I press a letter on the keyboard, the PT100 immediately freezes.
But only when I output data on the RS232 interface. As long as I'm in the parameter menu, every key can be pressed normally.
The 3V battery is of course empty (but I assume that this only saves the parameters when it is turned off)
I then tested the 6116 RAM with a chip tester. This RAM IC is OK.
then there are the RS232 ICs, the ICs U6+U7+U10
(as DS1489 and DS1488).
I thought that the DS1488 might be defective because it is responsible for data output.
I replaced U6+U10 (as they already had a socket), but unfortunately nothing changed.
There is another SRAM IC, SRM2016C12. I have just ordered this as a spare part.
Hence my question, does anyone know more about this device, and I am looking for the circuit diagram as schematics.
I am slowly running out of where to look: It is also not that easy to measure the operating voltages,
as the keyboard is sensitively wired and you have to turn the board over.
Otherwise I also have an oscilloscope here.
Thank you an greetings
Mikel
Mikel
