Chuck(G)
25k Member
termcap/terminfo is used to tell Unix/Linux programs how to communicate to a physical terminal connected to Unix/Linux. That is *not* terminal emulation. If you have a Wyse 50 (do any still exist?) connected to your PC then that might help. But, I took your original request to be that you have some legacy application(s) running on vintage hardware that emits Wyse 50 ESC codes and you need some way to handle those on Linux. for that you need a Wyse 50 *terminal emulation*, not Wyse 50 termcap/terminfo.
To answer your question, even though I don't think it is what you want, on my system the terminfo files are part of the package "ncurses-term", which you would need to install. Again, I don't believe this is what you need.
Minicom, however, is a terminal emulator and terminfo tells it what terminal to emulate. See here and here.
