Great Hierophant
I would dearly love a monitor that could support all of the following:
TTL signal input for MDA/CGA*/EGA with support for 15, 18 & 21kHz (200/350 lines)
Analog RGB input for Amiga, Atari ST, VGA from 320x200 to 1024x768 @ 50-70Hz.
NTSC/PAL field rate support (interlacing @ 25i and 29.97i)
NTSC/PAL color ccomposite & S-Video decoding
True Monochrome Analog (elimination of color burst)
Seperate Sync & Composite Sync
* - Color 6 should be brown, not dark yellow
Such a monitor could support the output of virtually every home vintage computer that has existed. Apple IIs use composite connections, as do most Atari 8-bits and Commodore 64s but some support separate Luma/Chroma (a.k.a. S-Video). Atari STs and Amigas support analog RGB monitors, as does the Apple IIgs. The IBM PC does as well through VGA, but the horizontal scan frequencies are higher than a more classic analog RGB display can handle.
The monitor should be a CRT, and should be of the larger variety (21"). Most vintage monitors seemed to hover around the 13" mark, but that is kind of small in today's world.
