Chuck,
Yes the Synchroguide always sounded like some sort of auto transmission that belonged in a car. As shown in the link you attached, in that system the DC control of a blocking oscillator was mediated by half of a twin triode. The other half formed a blocking oscillator with an additional "ringing coil" in its grid. This added a sine waveform into the grid voltage, so instead of having a slow inverted exponential rise out of tube cut-off it was a sharp approach, improving the noise immunity.The synchroguide doesn't have an input from the H output transformer, it normally gets its reference signal from the blocking oscillator output directly.
Sync circuits with diode pairs, like the 6AL5 were generally called "sync discriminator" circuits and these types produce a DC output proportional to the phasing of the H sync and the reference pulse fed back from the H output transformer, often from the width coil in vintage tube TV's. Solid state TV's tended to copy this design idea.
There was also third variant called "Syncro lock" I think another RCA idea which used an oscillator controlled by a reactance tube but it really was similar because the twin diode phase discriminator controlled the reactance tube and therefore the oscillator.
Prior to all that in very early sets, the H sync just got directly coupled to the oscillator grid with something like a 50pF capacitor.
