I'm down to what's pretty much my last-ditch effort in repairing my TI-99/4a - replacing the eight 4116 RAM chips.
The RAM I've removed is clearly marked at 150ns, and I've found replacements sold for as low as 99 cents per chip (without a minimum order).
However, I've found an equivalent chip marked at 200ns access time, but rated for the same length of RW/RMW cycle for only 14 cents per chip.
That said, just how critical is the address access time for RAM in the TI-99/4a? Would I be able to get away with ordering the 200ns chips since a read-write/read-modify-write cycle is the same length as on the 150ns chips, or would the longer address access time throw off other operations?
