iainmaoileoin
I have a TK50 and a few controllers. It is all I have by way of tape at this time.
I would like to see if I can get the tape to work.
I have pdp11diags etc available
BUT I cant find any diag image for the tk50 nor for the controller. Where else should I be searching?
Can anybody point me at an image?
I know folk say "throw TK50s away" "get an X/Y/Z instead" BUT I dont want to ;-)
I have no idea of the history of the controllers nor of the tape unit.
The tape unit loads/unloads tape, the pathways look clear, the wheels wheel and the rollers roll.
Ah, a thought, I made an IDC cable "straight through" to connect tape to controller - the cable is
good but should any wires be swapped?
If I toggle in some crude commands into to the CSR I can make the tape move - as yet I dont have
enuf skill (AKA time) to write C programs to start testing.
From other dimensions:
RT11 "crashes" during book when the card is present - no error messages.
bsd2.11 "crashes" (after I do a MAKEDEV tu0) and then try to access the tape (the tape does not
appear to move)
I do notice the CSR is seen at boot time and the OS claims the vector has been autoset OK.
Clearly something is borken.
I guess DEC diags would be the easiest way to fly?
Failing that, some adb or a C program running with access to kmem.
Or I will take other clues.
appear to move)
