Hi Pete
If you will recall, I said that the power supply module ( a transformer, fuse and rectifier ) may not be the issue. You may have blown the power brick's fuse with a failed part in the computer. As a beginner, you may determine to use the shortcuts suggested by others on this forum. Larry's post is a possibility as it is relatively simple. It is not good trouble shooting but it may get by. Most RAMs do not fail short. It does sound like the symptoms indicate a short someplace. It won't show anything if you've already blown the power brick.
First you need to determine if you've blown the new supply brick that Jay sent you. I don't think it is fair to him to return him a bad blown brick that was damaged by you.
You can also use the other shotgun methods of just going through and replacing all the capacitors on the motherboard. This again is poor trouble shooting You may damage the mother board if your desoldering skills are not up to par. You may actually fix the unit. The problem may not be the capacitors ( although highly likely that one has failed ).
As Chuck says, these can be repaired. There are few parts on these that can't in some way be dealt with.
Trouble shooting takes some skill and some tools. A minimum is a good meter. For trouble shooting I prefer an analog meter with a real needle. Still, one can use a digital meter and if it is the only one you are going to buy, I recommend one. Even the cheap $10 Harbor Freight meters are quite useful. I have one myself. I don't worry too much about it. If I accidentally run over it in the driveway, the loss is minor.
We can help you some remotely from the this message board. It does require you to learn some as we go and when we make request for information about an indication, you need to be concise with the answers. It can be frustrating for both sides but a few of us are used to it. We will try to be concise with our request for information.
Dwight
