Hello,
now I have a question for a TRS80 Model III, this computer was sent to me from the USA but during the trip it suffered serious damage, the CRT tube cracked at the neck and also two fixing brackets breaking sent to slam the CRT, with all its weight, against the flyback which in turn lifted off the PCB, and cutting the 6 wires of the primary coil.
I tried to rebuild the whole base part of the flyback and to solder the cut wires, according to how I found them in position, I only found 6 as there are 6 pins of the base, but on one of the pins I actually found 2 coil wires welded on it, I have not seen this seventh wire, perhaps broken inside the coil.
Replaced the CRT with one taken from a monochromatic AMSTRAD CPC464 monitor and mounted the original deflection on it, but in fact the monitor does not turn on, or rather only the heater in the neck of the CRT turns on but I don't see any image, even by changing the contrast and the brightness, checking the voltages I see missing voltages on the deflection yoke and the 80 volts that the transformer should provide for other functions, and probably the 12Kv is not present on the tube!
For this reason I have two solutions, either some kind soul up here has a video card for the TRS80 Model III to sell me (or even just the flyback) or I have to replace the monitor with some other. (With a logical pricing!!).
For the second case I was thinking of adapting a 12" PHILIPS monitor (monitor80) used on a C64, it has an RCA input, I think composite. If it possible i will try to place entire PHILIPS monitor tube and electronics into the TRS CASE.
To do this, however, I would have to convert the video signals of the TRS80 Model III but I still don't know where to start.
Does anyone have any advice or adaptable solutions for this? (Please not LCD adapting :D) .
Thanks
Emanuel
Thanks
Emanuel
