Trixter
First of all, every single Med-Res mode appear zig-zaged on the display (kind of flickering). Some spesiffic color combinations gives a totally washed-out picture. The only thing not flickering was the bars in the Horizontal retrace test.
I would expect this of composite output; I did not test with one, so it is very likely that some (most?) of the color combinations produce a bad picture.
Someday I'll add proper composite color monitor support to the program, but for now, assume the program is only relevant for RGB monitors.
Hi-Res mode appear fine, but compleetely without color.
Again, I'd expect that from composite output.
In the snow test, snow seemd to appear all over the screen, not just below the text.
Well THAT's odd. I was somewhat proud of that code; it specifically monitors horizontal retrace and doesn't start the snow test until after 16 scanlines of the display area have gone by. Do the horizontal colored bars work? That uses the same code. It is extremely strange for one to work and the other to not work...
The adapter changed to 80*25 after one test was run.
Yes, that's part of the reset procedure; when I exit a test, I call the BIOS 80x25 init to get everything back to a sane value (this is intentional, for better recovery on clones). You said this was on a real IBM CGA -- how were you running it otherwise? 40-column mode?
The only test not working as CGA (except the Snow test) was the Interlached test. Instead of one set of big letters filling the screen, the display is divided into 2 parts (horizontally on the middle) and the same text appear both on the upper part and the lower part. Is this actually how the Interlached mode should be?
No; see the example video for what it is supposed to look like.
