Terry Kennedy
I'm restoring a DEC TSZ07 (AKA Cipher M995S, I think). The company I got it from said that when they powered it on 10+ years ago, it displayed gibberish on the front panel display and then went dead. I disassembled and cleaned it and determined that they had let the magic blue smoke out of the power supply (quite badly - the PCB was completely warped where parts had burned up).
I sourced a replacement power supply and the drive now powers up and displays "TESTING" and "TESTPASS", and I can try to load a tape. It then reports "54 - MOTOR FAULT" during the load process - once the tape is wound onto the takeup hub, it seems like the supply motor tries to turn counterclockwise to take up the slack and that's when the fault happens.
The manual says that the troubleshooting steps are 3 - Turn it off and back on; 5 - Replace FRUs and 6 - Call DEC Field Service. The FRUs called out are 12 (supply motor) and 4 (servo circuit board).
Service Aid 111 (motor and servo tests) runs without error. Service Aid 525 (motor calibration) also runs without error and stores the updated calibration in the NVRAM.
Both hubs turn freely, with (as far as I can tell) equal resistance to being turned. There is a slight "tick" every 360 degrees on the supply hub, but if I'm remembering correctly from these many years ago, that's the linkage for the reel grabber jaws tapping on the actuator and not an optical encoder hitting something. Since the motor calibration procedure passes, I think the encoders are working properly.
Does anyone have any ideas about what to try next?
