Here are my thoughts on the various features of the Tandy TL:
Enhanced Graphics - Name a game that will use this mode that will also not work with an EGA/VGA adapter. Hercules graphics support is very convenient, but that can also be added with a card.
PSSJ Sound - Alot more games support the Sound Blaster than the digitized output of a PSSJ and you need a Sound Blaster Pro in order to select a DMA channel other than 1. Cloud says that the PSSJ will not give up DMA 1, and I want to use the Sound Blaster 1.x for the Game Blaster chips.
DOS in ROM - Not especially useful if you are using a hard drive, unless the hard drive is drive D. Useless for PC Booters, very useful if you have only have floppy drives.
101-Standard Keyboards - This is a very useful feature indeed. Those 90-key keyboards do not look appealing.
And the Tandy TX features:
Composite Video - This guarantees that you can use a TV for an output device. On the other hand, it may not show the same colors as an IBM CGA.
And as I've mentioned, the...joysticks can be disabled on the TL.
How is this accomplished?
None of the TL manuals give a setting to disable on-board peripherals in their setup programs.
Ok, I found it. Bit 1 of port FFEBh disables the joystick ports on the TL.
I have a TL2 if anyone's interested.
i'm a bit late to this thread. i have a 1000TX (and an HX) which i've found to be excellent for old-school gaming. luckily i got mine with a 20 MB IDE hard drive, which made it that much better. between the TX and TL it's basically a choose em based on your personal prefs i guess, but i'll tell you that it's very cool to be able to carry it over to the TV now and then for a bit of marble madness or ultima 6 on a bigger screen.
one major advantage of the TX is being able to output the tandy enhanced graphics modes to a TV, can't do that with the TL i believe.
Being able to see 320x200x16 screens on a big TV is important to me, and more to the point, it preserves the composite color capabilities of many games. With a TL I would have to stick a CGA card for any composite color, and then only CGA composite color.
The TL is a much more flexible machine, virtually all of it can be disabled. You can put in a high density floppy controller, a standard gameport, a bidirectional or better parallel card that would be LPT1.
