gwiley
Well, true, it's what we have now. But for some modules it can be a bit challenging to debug a bad one. For example, find a bad IC in an 8300/8310, or EAE, or an M8357 floppy controller, or one of the RK8-E boards... or the Plessey PM-DC/8 controller (Plessey version of the RK8-E)I think that's called a PDP-8/E (or /F or /M or /A)!
https://forum.vcfed.org/index.php?threads/hardware-plea.1244763/
Does anyone have a spare working RK8E or Plessey PMDC/8 RK05 Controller board set that might be looking for a good home at a reasonable price? Pretty Please !
I have two Plessey PMDC/8's and neither of them work very well. One passes the diskless maindec but can only read and write some data and hangs on the Disk Read/Write maindec. The other one fails on the diskless maindec.
I don't have the electrical debugging knowledge to fix something this complicated so if someone can help in that respect instead that would also be appreciated. If necessary I can provide the extender board and over the top extenders to aid in debugging.
An automated tester would identify the fault area and fault diagnosis assist capabilities such as loop the test or loop on fault... quite useful functions in the existing Flip Chip tester.
