The last time I used those cards, they were in a '286 with 1Mb RAM on the mainboard, so they should still be set up for that configuration, cause I didn't change any switches or anything. They should appear at the 1Mb boundry, and go up to 5Mb. Do you know for sure how much base mem your machine has in it? If it's only 640K, then you'll need to re-configure both cards to come in at that address. If your machine doesn't have any memory at all, you'll need to set the low-addressed one to begin at 0K. (IIRC, the Wyse machines were backplane-based, with the CPU, mem, etc. on daughter boards). There is a switch setting on the AST boards to determine how much of it is conventional memory, expanded, or extended. You'll probably not want any expanded memory, as your operating system should have a memory manager that will use extended memory to emulate expanded if it needs to. If you study the switch charts long enough, they should begin to make sense (a little knowledge of hexidecimal doesn't hurt either).
--T
