fritzm
So, the ESC key on my VT52 seems not to be functioning (no key click or character sent, depressing with a little extra pressure and/or wiggling the key while depressed doesn't seem to help).
Any advice on repairing/replacing these keys before I jump in this weekend? Can the keycap be removed from the front to check the mechanism, or will I need to remove the keyboard PCB and desolder the key mechanism to asses? Are compatible replacement mechanisms available if needed?
I was in the VT52 recently to make some repairs, so I am aware of the disassembly that will be required to get to and remove the keyboard PCB.
thanks much,
--FritzM.
thanks much,
--FritzM.
