Texas Wanted: BIOS EEPROM Flashing
Covers: Texas
GiGaBiTe
Austin, Texas
Is there a good method for sourcing a TAG chip? I'm looking at pictures of other 486 boards like the 486SPM and seeing if they have different chips, which some do, but the only source of them would probably be fakes from China.
Unfortunately, there's really no good source. TAG chips aren't documented well, so you'll have to do a lot of research on what part you need, based on what amount of cache you want installed. The best thing right now would be to remove all of the cache, because it won't work at all without a TAG chip. The only place I could recommend that has a better chance of not having fake parts is utsource.net. They deal in obscure and old chip stock.
Based on the motherboard diagram, you'll either need a TAG chip with 8kx8 for 128k of L2, or 32kx8 for either 256 or 512k of L2 cache.
Pickelhaube808
San Antonio, TX
Not really expecting any more advice here since options have run dry, but thanks to everyone who posted on this thread.
Tried removing all of the cache, tried a different CPU, tried a bunch of different jumpers I had not tried before and even ones not labeled in the manual, no luck.
Guess the board's screwed up somehow... $80 down the drain. Hoping the new board coming in works though.
