I decided to start a new thread for this topic, which started here.
I am installing a Seagate ST-251 into an IBM 5150 which has an upgraded PSU and the latest BIOS. I do not know what BIOS is on the WD1002A controller card.
I got into the configuration using (debug, g=c800:5) and it first asks about Interleave (I left the default of 3). I said yes to dynamic configuration and entered "820 6 821 821 11 3" - then asks if I want to configure virtually? I chose N. It then begins formatting and immediately throws an "Error---completion code 80".
Does my cabling look correct? The edge connectors at the hard drive only go one way. However, I wasn't certain for the orientation on the controller board header. Also, do I need to consider anything else like termination? Or which edge connector position I use on the cable?
