Roland Huisman
Where do I sign up as a beta tester?
I think you just did.Where do I sign up as a beta tester?![]()
/ I used this as a start. The 1st three statements of LOOP1 were removed and
/ in their place I hardcoded the TITLE and and loaded it so as to work as the
/ keyboard entry did. I limited the entry to 9 characters, 6 for filename, 2 for
/ext and a dot. Maybe this helps?
ADDR=20 /20 PUNCH, 40 TELETYPE
TPLS=6006 ADDR
TPSF=6001 ADDR
/ TAPE LABELER SA=200, CORE=200-734
/ BY JOHN WILSON 05-JAN-85
/ MODIFICATIONS TO FONT BY DAVID GESSWEIN 13-APRIL-14
/ ECHO TYPED INPUT ON HIGH-SPEED PUNCH
*200
LOOP1, KSF /WAIT FOR INPUT
JMP .-1
KRB /GET IT
AND P0177
DCA TEMP
TAD TEMP
TAD M0141
SPA
JMP UPPER
CLA
TAD M0040 /CONVERT TO LOWER CASE
TAD TEMP
DCA TEMP
UPPER, CLA
TAD TEMP
TAD M0040 /CONVERT SPACE::BACKARROW TO 00::77
DCA TEMP /SAVE
TAD TEMP /GET IT BACK AGAIN
CLL RTL /*4
NOP /(BUG FIX, REPLACING 7006/RTL)
TAD TEMP /*5
TAD BASEM1 /ADD TABLE BASE -1
DCA 10 /SAVE IN AUTO-INDEX LOC
TAD M0005 /INIT COUNT TO -(# OF COLUMNS), CLEAR AC
DCA COUNT
LOOP2, TAD I 10 /GET NEXT COLUMN (AUTO-INDEX)
TPLS /PUNCH IT
TPSF /SPIN UNTIL DONE
JMP .-1
CLA /AC=0 FOR NEXT TIME
ISZ COUNT /DONE ALL COLUMNS?
JMP LOOP2 /LOOP IF NOT
TPLS /PUNCH ONE MORE COLUMN OF ZEROS
JMP .-1
JMP LOOP1 /BACK AROUND FOR NEXT CHAR
/ DATA (BESIDES LOCATION 10)
M0040, -40 /-40 (OFFSET FROM BLANK TO 00)
P0177, 177
M0141, -141 /(A)
TEMP, 0 /TEMP FOR COMPUTING INDEX INTO TABLE
M0005, 7773 /-5 (- # COLUMNS PER CHAR)
COUNT, 0 /COLUMN COUNTER
BASEM1, . /BASE OF TABLE, -1
DECIMAL
0;0;0;0;0 /SPACE
0;0;223;223;0 /!
0;7;0;7;0 /"
40;255;40;255;40 /#
134;137;255;137;113 /$
131;99;24;198;193 /%
108;146;172;64;160 /&
0;0;7;7;0 /'
0;60;66;129;0 /(
0;129;66;60;0 /)
84;56;255;56;84 /*
16;16;255;16;16 /+
0;160;64;0;0 /,
16;16;16;16;16 /-
0;192;192;0;0 /.
128;96;24;6;1 //
126;161;137;133;126 /0
132;130;255;128;128 /1
194;161;145;137;134 /2
66;137;137;137;118 /3
12;10;137;255;136 /4
199;137;137;137;248 /5
126;137;137;137;114 /6
1;1;249;5;2 /7
118;137;137;137;118 /8
70;137;137;137;126 /9
0;96;96;0;0 /:
0;128;96;96;0 /;
16;40;68;130;0 /<
12;12;12;12;12 /=
130;68;40;16;0 />
4;2;177;10;4 /?
56;68;154;188;152 /@
254;9;9;9;254 /A
255;137;137;137;118 /B
126;129;129;129;129 /C
255;129;129;129;126 /D
255;137;137;137;137 /E
255;9;9;9;1 /F
126;129;129;145;243 /G
255;8;8;8;255 /H
129;129;255;129;129 /I
96;128;129;127;1 /J
255;8;20;34;193 /K
255;128;128;128;128 /L
255;2;12;2;255 /M
255;2;60;64;255 /N
126;129;129;126;0 /O
255;9;9;9;6 /P
124;129;161;65;190 /Q
255;25;41;73;134 /R
134;137;137;137;113 /S
1;1;255;1;1 /T
127;128;128;128;127 /U
63;96;192;96;63 /V
127;128;112;128;127 /W
195;36;24;36;195 /X
3;4;218;4;3 /Y
193;161;145;137;135 /Z
0;255;129;129;129 /[
1;6;24;96;128 /\
129;129;129;255;0 /]
4;2;255;2;4 /UP ARROW (^)
128;128;128;128;128 /_
0;1;2;4;0 /
I'm also facing this issue of discoloration of the +5V pin on the power supply connector. It seems likely to be a common problem with all 8/m systems. I'm seeing a worse issue with the quick-connect connection crimps at the ends of the wires that attach to the backplane.BTW, I had to replace some of the power supply connectors in 8/e systems at LSSM recently. Mouser has the parts. Ping me if you would like the part numbers.
-Dave
photo is in: https://forum.vcfed.org/index.php?threads/what-did-i-do-to-my-pdp-8-today.77577/post-1247620"Here is my 11/10, it has the same power supply as the 8/F or 8/M. I've added an extra set of wires between the 5V capacitor on the power and the backplane. Originally I had a voltage drop of 0.7v between the power and the backplane."
@mcguire (Dave) could you share the connector pin and shell part numbers that you found at Mouser? I think we can all benefit from this.
Thank you! You're correct, the 8/m is different... it has 9 pins instead of 6. The 8/e part numbers got me in the ballpark and was able to find what I'm pretty sure are the 8/m connectors which are a cousin of the 8/e. I'm going to order shells, pins and sockets to confirm.Hi, these are the 8/e connectors, which I'm pretty sure (can't picture it right now and I'm not near one) it's different from the 8/m. But here's the 8/e connector info, for the H724 power supply:
TE Connectivity Commercial MATE-N-LOK
Power supply side:
Shell 1-171196-0
Pins 60619-1
Cable harness side:
Shell 1-163035-0 or 1-480276-0
Pins 60620-1
For these connectors, I recommend coating them with DeOxit before mating them. This will stave off the high-resistance problem later on.
-Dave
What I think is probably the 8/m Power Supply side, TE Internal #: 1-480274-0
https://www.te.com/usa-en/product-1-480274-0.html
uses the same 60619-1 socket terminals for 20 AWG to 14 AWG
and what's probably the 8/m cable harness side,
https://www.te.com/usa-en/product-1-480277-0.html
uses the same 60620-1 socket terminals for 20 AWG to 14 AWG
Phosphor bronze sockets and pins are the -4 versions.
There are Mouser "shop now" links from both of the above TE pages.
Tyco catalog/datasheet with technical details of shells, pins and sockets is here:
That's an impressive piece of work for a custom 8E front panel. Looks like the power and selector switches are DEC originals. I get the impression it could be an 8F (LED-style) front panel that needed toggle switches. He had some PDP-15 (or DECsystem KA10) ones handy?.. The front was made by a DEC Professional, I think somewhere in the 90s. ..The front is LED. But the switches are more like a PDP15 or PDP12.
Have fun,
gnupublic
Where's this? I went looking at bits/ and pdf/dec/pdp8 but didn't find it.A file dump on Bitsavers recovered more of DECUS-8-250 signal capture and FFT program
http://www.bitsavers.org/bits/DEC/mixed_media/Where's this? I went looking at bits/ and pdf/dec/pdp8 but didn't find it.
Vince
