cmc
Hi VCF folks,
I have an ENPC EP-PT11 motherboard from the Pentium 1 era. It's dead. The question is *why* is it dead?
The board isn't worth much and probably I should just pitch it, but I am too curious a person to not at least have a theory about what killed it.
1) There is no obvious physical damage to the board.
2) There were not capacitors swollen or leaking, but I recapped it anyway.
3) I thoroughly cleaned every socket, thinking maybe it was an electrical problem.
4) Tested with both a P1 133 and an AMD K6 233.
5) Tested with several different ram chips.
6) Quadruple checked all jumper settings against both the manual and what is printed on the motherboard itself.
7) Tried two different PSUs.
8) As a last ditch try, I baked the motherboard at 375 degrees F for 10 minutes, to reflow it.
So... what typically goes wrong beyond these things? At this point I'm not even trying to fix it really, I am just wanting to understand at a deeper level what went wrong.
Behavior is that it turns on, runs for five seconds, then turns off. No beep.
