84TAVeRT
i have come to the conclusion that the extra card in my new to me XT clone is a z80 cpu card...
anyone know what it is good for?
thanks,
Chris
thanks,
Chris
More common that you'd think.
Of course, you need the drivers to interface the PC to the board, which may be fairly difficult to come by.
If you have a V20 installed in the 8088 CPU socket, you can also run CP/M without any special cards...
Can you tell something more, please?If you have a V20 installed in the 8088 CPU socket, you can also run CP/M without any special cards...
I've got two mobos with NEC V20 and Sony CXQ70108D (second-sourced V20?), and they indeed run many programs for CP/M-80, but I've never tried running the CP/M itself, thought it's too hardware-dependent to run on a PC...
EGA was the lowest color resolution system that Windows 3.1 would work on.(I think)
From the other thread the picture you had shows an EGA card. I never knew exactly why those RCA jacks were there as I never saw any labeled before. You can try hook the card up to a TV instead of a monitor through a "composit" connection. Other then that...EGA was the lowest color resolution system that Windows 3.1 would work on.(I think)
i don't think the EGA cards used a Z80bCPU chip or a 12mhz crystal...
i did find some numbers on the card...
Audio Visual Laboratories, Inc.
27122 R0I
M14A 94V0
Serial Number 1518
i know i looks like an EGA card, but it doesn't even try to initialize a monitor on the rca jacks or the 9-pin port...
Sorry to necro post. I just cracked open an IBM XT from my basement and it has this same card. My Google search's brought me to this thread. It does appear to have its own ram, CTC (Clock Timer Circuits) etc. I think this came from MassMutual back in the 90's and we did have a in house TV studio so it very well could have been a control interface. It even has the same paper label "GEN 07/11/84" on U15.
http://www.stevenmichelsen.com/AVL/ <--- Should look familar
