Any Old flatscreen with vga will work.
If not vga then an active adapter from it to hdmi
It seems to be a non-standard cable attachment. An ordinary VGA cable won't fit the back of the computer.
Your VGA cable has one extra pin, doesn't it?It seems to be a non-standard cable attachment. An ordinary VGA cable won't fit the back of the computer.
Pin 9 isn't used in the normal VGA spec (unless it's a really niche product) but some vendors leave the pin disconnected while others plug the hole/remove the pin. If you can't plug a cable in because of pin 9 it is okay to break off pin 9.
VGA Cables 14 vs. 15 Pin Cables [15 pin ver] | StarTech.com | Canada
Why does this VGA cable have pin 9 while others are missing it? | Canadawww.startech.com
