What PC display adapter is this program for? (ST100A.COM)
VileR
Israel
I've finally started dumping a rather sizable pile of floppies, which date back from my family's first no-name XT clone (~'87 or so). The first batch turned up a copy of the TSR attached here, which is related to the video adapter.
One thing I don't really know is what video adapter we actually had in there, so that's what I'm hoping to find out. I had a look into what the program actually does, so my IDA-assisted disassembly is included too.
What I remember:
  • The card was CGA-compatible (at the hardware level, since it ran the usual suspects like Digger and Round 42)
  • The monitor was monochrome, but displayed true 200-line CGA video (in shades of green)
  • 80-column text mode was CGA-like by default (200 scanlines, 8x8 characters)
  • However, the card could *also* display sharp MDA-style text on the same monitor (80x25 text only; no Hercules graphics or anything)
  • "ST100A" was the program that let you switch between the CGA-like and MDA-like text display.
What ST100A.COM actually appears to do:
  • Writes 40h to port 3DDh
  • Sets up an alternate Video Parameter Table, points INT 1Dh at it, then sets video mode 2 (B&W 80x25 text)
  • Installs its own handlers for INT 09h and INT 10h (keyboard and video), then terminates & stays resident
  • You can then hit Alt+[, Alt+], or Alt+/ to control the behavior of text mode.
Looks like "normal" CGA text mode requires sending 00h to port 3DDh, restoring the default Video Parameter Table, then setting mode 2 or 3. Writing 40h to that port (and setting up the alternate VPT) gets you the MDA-type mode instead.
If that's right, then Alt+[ sets up CGA text, Alt+] sets up MDA text, and Alt+/ flips between the two. (The keyboard handler also watches for Ctrl+Alt+Del, and sets up CGA text again before the warm boot.)
There's some other stuff in there too, like cursor handling; but it seems like port 3DDh may be the key here, since it's non-standard.
It's a long shot, but given all that - does anyone have a clue what hardware this was meant for, exactly? :)
  • ST100A.zip
You brought this up in 2011 and got no answers. My guess is that it was for one of those hybrid CGA/MDA cards, since you're writing to 3Dx and not 3Bx.
Hmm... if you mean this old thread, it's only kinda-sorta related; has more to do with what various CGA-on-monochrome solutions looked like, in general.
Back then, I didn't have the actual program handy. It's indeed a hybrid CGA/MDA card as mentioned above, but I'm hoping (against considerable odds...) to find out which one it actually was. Or at least the general direction, e.g. a particular chipset or something like that.
Yes, quite sure that's not it - it says that on a Plantronics, writing 40h to port 3DDh means "swap planes" in graphics mode; nothing about MDA-like text functionality there.
It could be something like that, but then it could be any other MDA/CGA combo card ever created, so it's a shot in the dark. :) I have a hunch that the card was simpler than that (Plantronics support would've been overkill for our system); perhaps more like the Compaq dual-mode card as used in the Portable II, in terms of capabilities.
I might as well post this to VOGONS, too. I suppose the only way to know for sure is if someone turns up a card with this program included (or with documentation that mentions it).
What strikes me about this code is that nowhere is there a check to see if the display adapter is what is intended, so conceivably, there could be adapters with a port at 3DD where this action would cause things to go south.
A simple check for a BIOS signature would have sufficed. This makes me wonder if this wasn't intended for a system with the display adapter on the motherboard.
Do you know what kind of monitor this was paired with? There were monochrome monitors like the Princeton Graphics MAX-12 which supported hardware CGA emulation (IE, it natively took RGBI and converted them to shades of green/amber) and MDA on a normal 9 pin video connector, was it one of those or something more proprietary?
It's interesting that its "MDA-ish" mode is still Mode 2? My memory's fuzzy but isn't MDA text Mode 7? When it was in this MDA-ish mode did it use MDA attributes or CGA greyscale? The first rotgut XT my family had back in the day had the aforementioned MAX-12 paired with a card that as far as I know only did CGA, so I have no idea if it was possible for that particular monitor to do 16 grays when it was running at MDA frequencies. (I did later have that monitor connected to a Hercules card, but of course a standard Hercules only has MDA's video/intensity lines for effectively four greys.)
Edit: Here's a long shot for you. I did a quick Google to see if it was possible that Princeton Graphics might have made a special video card for the MAX-12 that allowed it to modeswitch like you've described, and I hit this page describing a Paradise "Modular Graphics Card":
https://stason.org/TULARC/pc/graphi...EMS-INC-CGA-MODULAR-GRAPHICS-CARD-VER-64.html
It has DIP switches for supporting several different kinds of "enhanced" monitors including the MAX-12, could the program in question be for it?
It wasn't an on-board adapter (later on we swapped it out for an EGA card and went for a color EGA monitor); the motherboard itself was the common Taiwanese no-name Turbo XT type, IIRC. I guess a CGA/MDA type board wouldn't normally have a BIOS extension, so a signature check wouldn't have worked.
Then again there are other eyebrow-raising things in that code, like the unnecessary use of ES and the prefix abuse that it entails, so go figure. :)
Definitely not a Princeton, but yep, it probably worked on the same principle. I believe the early Compaq Portable/Deskpro monitors were also like that for instance.
FWIW, I think the monitor was labeled 'Minta' (yet another generic Taiwanese brand?) - it looked exactly like the one in this photo with the grey inner bezel.
Yeah, on MDA/Hercules it would be mode 7. But if the card didn't have its own BIOS (like most CGA/MDA type cards), it would have to identify itself to the BIOS as either one or the other... in this case it apparently identified as CGA, so mode 7 wasn't available; I guess that's why this program was needed.
As far as I can remember the "MDA-style" mode still showed shades of green for CGA colors, as opposed to MDA attributes with underline and so on.
Could be one possibility, heh. That's some comprehensive monitor support there- makes me wonder what was so different about all of them...
