The 16K RAM board works beautifully, the system comes up 32K now and I made a memory test program to test it which is working great.
The ROM board was a little more trouble. This PCB has a couple of issues that I will need to resolve. The 74LS00 SO IC is wider than the footprint I used for it so I had to cut the pins a bit off and bend them to make them contact the PCB. Also, I forgot to put a hole in the back of the PLCC so it could be pushed out if seated too deep. One of the 12V rails didn't have enough solder mask and was shorted to ground resulting in a very bizarre video of odd characters and lines. Once I fixed that it began working as expected. I can finally load extended basic!
The little switch on top allows you to enable or disable the board without having to unplug it...
