My PC-6001 had a bad diode in the AC DC rectifier that once replace fixed things up. If you can disconnect the rails from the main board, you can measure resistance on those rails to see if any are shorted. Though they may not show as shorted until power is applied, and small clamp meter on them could show you the current to see if it is over spec. Also, if there are any bad tantalum caps, if you have a thermal camera, they will show up as heat if they are shorted.
