NOT All Baby AT motherboards will fit into the IBM 5160 metal case.
Those that are an ~ 1 inch longer than the IBM-XT motherboard will hit a metal case support for the Left Drive Bay. That piece of metal is bent down from drive bay and “Spot welded” to XT case bottom.
Check dimensions before fitting.
DO NOT TRY. to Fit Modern Motherboards (Last 25 years) into Legacy Cases (XT, AT, Baby AT).
I have seen BAD HACK Jobs by those with No Skills, No Talent.
In 1995, INTEL set the New Computer Motherboard Form Factor ATX Standards.
Introduced in 1995, the ATX was the first PC motherboard to not only include I/O support (serial, parallel, mouse, etc.), but to place all the connectors directly on the motherboard. Prior to the ATX, only the keyboard connector was attached to the motherboard.
Advanced Technology EXtended motherboard) The PC motherboard that superseded the Baby AT design. The ATX layout rotated the CPU and memory 90 degrees, allowing full-length expansions to be plugged into all sockets. The power supply blows air over the CPU rather than pulling air through the chassis.
Numerous variations of the ATX were subsequently introduced with both smaller and larger form factors, including the microATX, Mini ATX, FlexATX and Extended ATX.
BTX was another form factor (mirror image) that was designed for servers and workstations 20 years ago.
It was Unsuccessful — Brand New Lenovo cases (BTX, empty) are seen on eBay, Alibaba.
DO NOT BUY, unless you have that motherboard (Dead End)..
