Writing Osborne disks with ImageDisk
I need to bulk erase the DS-DD disk before I can use it in a DS-HD drive? I'm a bit confused on that bit.
The bulk eraser is a bit old.the Realistic 44-210. It's old enough the box art shows someone erasing a reel and an 8-track. :)
That should do it.
The reason is that a 96 tpi drive writes a track only half as wide as a 48 tpi one (the kind the O1 has)--and you're writing every other track (double-stepping) So if you don't bulk-erase a DD disk before using it, the O1 drive head will also pick up the background "noise" between tracks and create read errors.
Okay, so I move Imagedisk and the disk images over to an AT&T PC 6300 which is fitted with a 360K double density drive.
I fire up Imagedisk and try to write:
0 sectors
Write Complete
...and that happens. It does nothing.
