Here are the boards I have:
[TABLE="class: grid, width: 1500"]
[TR]
[TD]
Make/Model[/TD]
[TD]
Image Link[/TD]
[TD]
Info[/TD]
[TD]
Other Links[/TD]
[TD]
Notes[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]BioStar MB-8433UUD-A[/TD]
[TD]
Images[/TD]
[TD]
Board Info and Settings[/TD]
[TD][/TD]
[TD]Socketed Dallas RTC, probably dead. Has place for coin cell holder to soldered on.
AT Keyboard with PS/2 mouse ports[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Everex FX-3000 Rev 1 / ECS US 3486[/TD]
[TD]
Images[/TD]
[TD]
[TD]
Motherboard Manual (I think)[/TD]
[TD]Supports both 386 and 486 Processors
No onboard battery (has 4 pin header for external battery)[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Genoa TURBOEXPRESS 486VL[/TD]
[TD]
Images[/TD]
[TD]
[TD][/TD]
[TD]The arm that hold the CPU down is not quite aligned, but it hold it in place without issue.
3.6V Barrel battery shows no signs of leaking, and is holding strong at 3.6V when measured (hence it not being removed).[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Soyo 4SAW2[/TD]
[TD]
Images[/TD]
[TD]
Board Info and settings[/TD]
[TD]
Drivers/BIOS/Manuals[/TD]
[TD]Minor corrosion from where I removed the battery. Board works 100% though.
There is a 4 pin header for an external battery. Corrosion will probably clean up just fine (I did not try).
PS/2 Keyboard Connector, and PS/2 Mouse header.
Supports a very large number of 486 based processors.[/TD]
[TD][/TD]
[/TR]
[/TABLE]
All these boards were tested as working by me before being stored, and I will re-test before accepting money from a potential buyer.
Let me know if you are interested in any. Shoot me a PM with an offer and we can go from there.
