modem7
10k Member
You need to get the hard drive type number into the CMOS SETUP.However, I never configured the machine's BIOS in BASIC because I never got a Lithium battery that would work to keep the BIOS options set. I did not want to type a bunch of lines of BASIC just to turn it off and not have it work.
Without a battery, if you want your machine to boot from the hard drive, then every time you power on your computer, you will need to:
1. Boot from a boot floppy that has something on it that allows you to configure CMOS SETUP; then
2. Configure CMOS SETUP, specifying the hard drive type number (in addition to the other CMOS SETUP stuff); then
3. Reboot (CTRL-ALT-DEL).
Alternatively, you could configure the CMOS SETUP from BASIC. It's just another way of accomplishing the same thing.
I'm sure that you don't want to go through that process every time you power on the computer.
