Okay, I now have a correctly formatted floppy (I used Format A: /T:80 /N:9) with pcdos330_720k.exe on it. I booted the computer with it in the drive and nothing special happened. No DOS. What'd I do wrong this time? Ha-ha...
Of course, as mentioned earlier, the battery in the 5162 is probably 'dead', which means that any CMOS/SETUP configuration done now will be lost when the 5162 is powered off.
I had to do Basic. I think I may need to replace the floppy drive; that's okay; I have a few lying around that should work. What is my display type? I have a Princeton Graphic Systems HX-12+.
Looking back, I can see that you managed to configure the machine's CMOS SETUP (via BASIC). During that procedure, you would have specified the hard drive 'type number', which for the XT/286 is a number between 1 and 24. If that number was not set correctly, then the XT/286 is not going to boot from your DOS-already-installed hard drive. Reading back, I can see that you established that your hard drive type number is 2. Are you confident that that is the correct number, and that it has been configured in the CMOS SETUP ?Now I have a new problem. My C: drive is apparently dead. The light turns on, and it seems like it is even spinning, but it does not boot to DOS, so it must not be working right.
