Howdy I have a Tandy 1000 TL with three floppy drives, A,B,C. The rom based dos 3.3 becomes d. The boot up shows the compact flash card as master, but after that it does not show up, even though it's formatted for dos.
If I run the setuptl.exe /a and tell the computer I only have 1 floppy, it will boot from that disk, and then I have access to the compact flash, so installed dos 5.0 on it, but I cannot get the computer to boot from the compact flash. Floppy yes then access the drive but not from the drive itself...
When I did the dos 5.0 install it all went well, no errors, but it will not boot from c.
Only A. I did see that error 1h! At one point but not sure what is going on...
Hoping to have at least 1 3.5" and 1 5 1/4" drive along with the compact flash.
Is it possible to disable the built in dos?
Any help appreciated. :0)
P.s. The boot on the card (isa to compact flash card from Lo-Tech) is at C000 the default and at 0300
Cheers!
