dominicbeesley
Hello,
I've finally got my z80 homebrew machine going its only 25 years since I first wanted to build one!
At the moment its very simple but I'd like to (try to) interface it to a 1980's VGA card. I have an old ISA VGA card (pictured) it's marked "CT-8490 Magic VGA" and uses the "Cirrus Logic GD510A" chip-set.
The thing that worries me is that there is a DIP switch at the back I've no idea what the switches do, nor do I have an ISA machine in which to try it so the long shot is - does anyone know what the switches do! I remember they could be a pain to get working even if you knew what the switches were supposed to do!
Does anybody have any other advice about interfacing z80 stuff to an ISA bus?
I was going to tie A20 high and use a D-type latch for A19..A12 (output enabled when A15..A12 and MREQ of Z80 high) and make a 4k window in my memory map to access the VGA memory and a similar arrangement for IORQ. Not sure what other pins of the ISA bus I need to worry about?
Should keep me quiet for a good while!
Cheers
Dom
Cheers
Dom
