I've really got used to zcpr on Kaypro, and now having created a bootable 800K MM CP/M image for gotek, I really miss zcpr functionality. For Kaypro it came with a nice installer on micro cornucopia disks. I started to look for something similar for MM. And I have found this archive that contains the following installation instructions in READ.ME file:
The archive does not contain this SYSIMAGE.OBJ file. I am not sure where this one is supposed to come from. There is a script to recreate it from running system as follows:
But I am still not sure how to get an actual zcpr3 into the system. Searching for zcpr3 did not lead me to any generic installable package with instructions. There are a lot of bits and pieces around, including source code, bunch of *.lib or other mysterious files, for example here.
So if anyone could point me to some coherent package with instructions that could be applied to this case, please do.
1. Format a bootable CP/M system disk under Montezuma CP/M
2.2.
2. Copy SYSIMAGE.OBJ onto this disk. This *must* be the
first file copied onto this disk.
3. Copy INITLIZE.COM and DU.COM onto this disk.
4. Run DU.COM and issue the following commands:
G2
<;-68;>;W;+69;/72
X
5. Put this disk into drive A: and push RESET.
ERA SYSIMAGE.OBJ
DU T0;S1
Y;+;/72
KSYSIMAGE.OBJ
X
