JAXVintagePC
When we moved into our new home last year I converted the CAT3 station wire that was used for the telephone lines (house was built in 2000) (rated for 10MBPS 10BASET) to ethernet. We now run 1GBIT on most segments except for one from the living room to a bonus room above the garage that is limited to 100MBIT. That was a fun experiment. Each room that wants to use ethernet has a switch since the telephone wiring was daisy chained (and stapled into studs) as was the standard back then.
I also successfully used MOCA on RG59/RG6 that is installed in the house (and stapled into studs).
A successful and interesting experiment is that I can connect modern and vintage PCs using the same RG59/RG6 cables in the walls for 10BASE2 using F-connector to BNC couplers. With 50OHM terminators it still works on the 75OHM rated cable. And with some Accton HUBs that have both 10BASE2 and 10BASET I can bridge to 10MPBS with modern PCs without an issue.
It was also a relatively cheap experiment since these parts are cheap. Plus it is esthetically a lot better than a super long BNC cable I purchased for $5 at a local thrift store last year. My wife was very annoyed with that black cable running along the wall and over doors.
Unfortunately my house has two separate attics so running additional new wiring is relatively completed.
