Dwight Elvey
I'm not sure what was done. I suggest moving the ROM to another socket to see if the checksum was correct. I didn't expect the system to work that way. The socket's address is partially decoded. The ROM it self has additional decoding.
Are you saying that the ROM from erratic location now has a good check sum?
If so, it is either a bad socket or there is some type of contention with some other component.
As Daver2 says, the value from the keyboard looks bad. That may be related or just another possible problem. Dave_m suggested moving it to another socket but using the same select signal. Was that tried and what were the results?
Dwight
Dwight
