IBMMuseum
- Joined
- Aug 28, 2006
- Messages
- 1,488
Yes, the MCA bus was used on all 386+ PS/2 machines. The entry models 25 & 30 (XT/AT) use the ISA slot. I don't expect problems with fitting the card is the slot, but rather with the IRQ setting.
To be more correct, the 8086-based versions of the PS/2 Model 25 and 30 have 8-bit expansion slots (2 and 3 respectively) like the IBM XT. "ISA" to me denotes a 16-bit card and slot like an IBM AT. There are 286-based versions of the Model 25 and 30 ("25 286", "30 286") and a 386SX version of the Model 25 ("25SX") with "ISA" slots (the 25SX has three 16-bit expansion slots, one is a "reversed" bracket designed for a special Ethernet or Token Ring network adapters).
There are other PS/2 models with 386SX, 386SLC, 486SLC2, and 486SLC3 CPUs ("386+"), but an ISA bus. Mike is right in saying there are several models (below the Model 50) that are not a microchannel bus. In this particular case (an 8-bit card on the Model 30) I don't think there will be an issue with an IRQ, unless it uses the same IRQ as a hard drive with one actually attached (the HDD controller is on the planar, but is deactivated if the proprietary HDD ins't connected).
