frozenfire75i
Banned
What about us with the 5161 EXP uint, will that tiny 500MB IDE drive be enough draw to keep that 130Watt XT Power supply happy?
Haha Where I come from power supplies do better with less draw.frozenfire75i: "... will that tiny 500MB IDE drive be enough draw to keep that 130Watt XT Power supply happy?"
The drives typically are letting me partition them, format them, and seem to be working but when I try to boot with them the controller goes off into never-never land and does not return.
Andrew Lynch
The XT-IDE controller works great with the WD AC28400R. It does everything you'd expect. I tried it with an older Quantum 270LPS and the controller recognizes it but does not work with it. Same thing for a newer Quantum 4.3 GB drive. Similar for an older Fujitsu IDE 1.2GB drive. Its seems there are probably some tweaks needed yet for these drives. I will be going through my limited supply of IDE drives and sorting out which work and which don't.
I think y'all otta be looking at a hardcard type of setup.
how big is the AC28400R?
I could see some issues with drives smaller than ~8 gig. The drive parameter table gets set up a little different in those cases, and I very well may have a bug there. As you've said, the ID string shows up fine, but FDISK and format are wonky. That's exactly how I'd expect a drive that has a weird parameter table set up to act, so this could be 100% my fault. For now, if you can stick with testing drives > 8 gig, then we could move forward while I figure out what the deal is on my end. This is very likely not a hardware problem.
Given the complexity of making a compatible IDE interface and BIOS I recommend we do a pre-release test phase to help shake out the bugs before a general release. It's something to consider to find the problems with experienced hobbyists before unleasing the controller to the public who may not have the experience or background to deal with problems they discover.
I have a pile if IDE drives here to try out...
I believe right now we're tied to a single IRQ, 5 IIRC. What needs to be done to work on a Tandy? Does it just have to be selectable to a different IRQ?
Either way, the BIOS at this moment isn't using IRQs anyway, so it'll work!
(that's temporary)
I think that's all that is needed.
See ftp://ftp.oldskool.org/pub/tvdog/tandy1000/documents/t1khdhow.txt
for some notes.
Kelly
Forgive my lack of experteeeze in this stuff.
But what is the difference between using an IRQ and not using an IRQ for this sort of stuff, IRQ=More stable?
The Tandy 1000SX needs to be selectable. I believe they use IRQ 2. I had to rewire my Western Digital controller back in 1987 to get the Seagate ST-225 to boot. I still have the wiring diagram and jumper settings if anyone is interested.Part of the benefit of this new device is that it works with new hardware.
While lots of us probably have a clunky old 200MB drive from 1990 in our closets, I think we're all better served by using more modern drives, which I'd hope are more compatible/flexible with our design hardware. IOW, I'm not going to spend a whole lot of time figuring out why a drive that is 15+ years old doesn't work, when a perfectly good, bigger and newer drive works just fine.
Just my opinion.
Having said that, I am certainly going to look into drives smaller than 8.4 gig for any BIOS bugs, but beyond that, I wouldn't break out the logic analyzer and scope to find that ancient drives are more finicky than new ones.
kb2syd:
(that's temporary)
