vwestlife
Since it's relevant to both projects (solid-state emulation of IDE-XT drives and making a new interface for existing IDE-XT drives), I'll say here that one thing I didn't mention in my video is that the cross-compatibility between brands in not universal. The Western Digital interface card will work with both WD and Seagate drives, but I couldn't get the Seagate interface card to work with my WD drive, even after experimenting with the jumper settings on it.
Also many years ago I was unable to get a MiniScribe IDE-XT drive to work with the built-in Western Digital interface in the CompuAdd 810, although I think that's just because I didn't low-level format it, and back then I didn't know that you could do so on any kind of IDE drives! FDISK did recognize the drive, but every attempt to format it using the normal DOS FORMAT command failed.
