giobbi
Hi all,
I have a spare, working 8032sk without keyboad and a faulty 3032 I'm one step away to fix it use gasoline and a match, since I'm trying to fix its garbage screen problem since 2001 (yes, I mean 12 years!) with no luck...
I was trying to find a way to use the 8032 working board inside the 3032 case. Yes, I'm trying to make the first 3032 at 80 colums
As first test, I tried to connect the 8032 board to the 3032 9" monitor. The image appears but it's quite messy (like when you drive a CRT above its max resolution: green background instead of black, text shifted, some horz. bright lines, etc...). I imagine (but of course I'm not sure!) the problem could be the 9" crt driver board. I'm assuming (better: I'm hoping!) the crt itself can support the 8032 resolution and the problem is just the 9" crt driver board...
So here's the question:
CAN I USE THE 8032 CRT DRIVER BOARD (the one inside the monitor, directly connected to the 8032 crt) ON THE 3032 9" CRT?
I was thinking to extract the board from the 12" CRT and use it to replace the one inside the 9" CRT.
- Will it blow, or will it work?
- Will it drive the 9" CRT at the 80 columns resolution of the 8032 board?
- Should I use the original crt transformer or whatever it is (I mean the one attached on the side of the crt with a "sucker" connector)
OR
Should I simply extract the "sucker" connector from the 9" crt and connect the one originally attached to the 8032 12" crt?
every suggestion is welcome!
thank you!
Giovi
OR
thank you!
Giovi
